What settings are you changing?If i try to set some settings, the web-ui went off.
What IP Address and Subnet Mask are you setting on the AP?The other thing is: The router only worked directly connected with the pc. Connected directly with the main router (as an AP) i can't reach the web-ui.
This a different description than you gave before. Which one is the truth?I gave the ac86u a static ip-adress, with subnet 255.255.255.0 and the main-router adress as gateway. This was also the configuration which worked for years. Today i only could see the web-ui if the router was connecteted directly to the pc. Connected to the main router nothing works.
Welcome To SNBForums
