Sky
Hello, Everyone!
I recently upgraded my broadband to gigabit over coax with Comcast (982/35 download/upload) and am seeing some issues. Hopefully wiser minds will point me the right way…
I have coax coming into the building from my ISP's branch box about 60' from the modem. When I connect a desktop directly to the modem via Ethernet I get Comcast's gigabit: 949.31/40.84 & 949.54/42.14. Reconnecting the desktop to the structured wiring which passes through a Gb dumb switch and out to the router I get basically 500/40. I excluded the building and switch from the group by wiring the desktop directly to the router and saw the same result, 500/40, so now I'm confident there is something about my RT-AC87R (aka: RT-AC87U) that is amiss.
Sky
- The AC87 appears to be capping the WAN-to-LAN download at roughly 500 Mbps ± 100Mbps;
- The inside LAN and all Ethernet components are Gb; and
- The AC87 handles DHCP for the LAN.
- Is this a known limitation of the AC87, i.e., gigabit WAN-in will be limited going out even through one of it's four built-in Gb LAN ports;
- Is the incoming WAN signal parsed in some fashion when exiting to the LAN;
- Is there some setting I can check or tweak or something; or
- Will I have to say goodby to my trusty 87 if I want Gigabit from the WAN through the LAN endpoints? << I really hate this option
Sky
