AC87U > AC68U Repeater > T-Mobile Cellspot = not working
d0g
My setup is
Modem > AC87U (Merlin 384.13_1) > AC68U (Merlin 384.13) Repeater > T-Mobile Cellspot
The Cellspot is not connecting. The manual says to open some UDP ports.
But the 68, as repeater, does not show options for port forwarding/triggering.
And the 87 does not show the 68's clients.
What am I supposed to do?
I also wanted to try the Parental Controls, but they are on the 87, which does not show the 68 clients.
Is there some reason you are not directly connecting the Cell Spot to your primary router using an Ethernet cable?
I have used a T-Mobil cell spot for four years and it has been plug and play behind a N66, AC1900P and an AC86.. No port forwards necessary. The only thing I do is assign it a static IP as I do with all devices that connect to my LAN regularly.
