Peter Shankland
Hi, I have my AC87U set-up in bridge mode to connect to my BT Smart Hub via 802.11ac.
The AC87U seems to connect fine but any device that I plug into it doesn't pick up a DHCP address from either the BT Smart Hub or AC87U. If I set the IP manually pointing both the default gateway and DNS to the BT Smart Hub all is well. This isn't ideal as some of the devices I intend to plug into the AC87U can't have fixed IPs.
I have looked around the interface of the AC87U but can't find anything for DHCP or DHCP relaying. Is there anything?
Thanks.
Pete.
Thanks.
Pete.
