Bought AC87U 2 months ago, flashed 380.58 instantly (I'm on 380.59 now) and experience problems with it since the first day (did factory reset 3 times total, didn't help).
1st issue is DLNA - At least once a week, my Samsung TV can't access router (so I can't access content from HDD attached to the router). Solving it is easy - login to router, and re-enable (disable, then enable again) DLNA. While it's easy, it's also annoying. Just checked logs, no single word mentioning DLNA, so not sure what else to look for.
2nd issue is VPN client. Very often (2-3 times a week) Internet connection stops working on all devices (except IPTV on my Samsung TV, this one continues to work, so my guess is that router doesn't apply VPN on IPTV port, which is fine for me). Again, the solution is simple yet supper annoying - login to router and re-enable VPN client. Logs always show a truckload of this error - "openvpn[12252]: RESOLVE: Cannot resolve host address: europe.vpn.airdns.org: Name or service not known"
I know it's NOT VPN's problem because once I disable-enable VPN on router, it starts working the same second. Also, when Internet connection was down (because router couldn't connect to VPN) I tested VPN using my phone - disabled wifi and was able to connect to VPN (using EXACTLY THE SAME settings for VPN on router and phone) with my phone via mobile data without any problems.
