AC87U NAT loopback
astroroxy
Does anyone else have an issue with NAT loopback?
It seems to work for about a day then I have to go and click apply on any page to reset the settings.
I am having a similar issue, but it appears to be more than just NAT loopback. All of my port forwards seem to clear out (12-72 hours). I go back in to the settings (where everything still appears) and click apply and then everything works again.
I also been having this issue. I have to go in and disable it and then re enable to get it working.
I had a problem when I first got the router, but a reboot restored loopback, and I haven't had any problems since then. I've run a couple different versions of -Merlin, now on .47
i have a same issue.
look 'system log', and find something like 'Oct 2 02:00:32 rc_service: rc 5030:notify_rc restart_wrs'
every 48hour, 'at 2am'.. restart_wrs?? makes nat loopback disabled.
goto firewall and click on or off. and apply.
you can make loopback enable.
I am seeing this exact same issue on all of the latest builds (including RMerlin's builds). It appears to be more than just loopback as I cannot reach my webserver from the outside when this happens. I will try other ports the next time this happens. I also have a 2am gremlin "rc_service: rc 3603:notify_rc restart_wrs" in my logs.
It would be nice if this got fixed as it is my only real gripe about this router so far. Fingers crossed!
I seem to be having this issue as well....This needs to get fixed ASAP...what's the point of router if you don't have working NAT/port forwards ?!?
