AC87U Settings Export
maxl96
Hi, I just set up my new router with all the configurations including DynDNS (no-ip.org)
After i was done, i went to the export option and saved the config file, just in case.
I looked back to the DDNS settings and they where corrupted now. (no Hostname was there)
Did anyone face the same issue? BTW I´m on latest firmware, and factory reset...
Tried to set DynDDNS again, but after export it was corrupted and not working again.
Edit: added some screenshot for you.
Edit2: I just found out that this is an Asus Bug and already fixed in Merlins Firmware.
2nd Question:
Is it the normal behaviour to get a new WAN IP if I change the LAN DHCP range?
