pascalgeraeds
My Asus AC88U is bricked,
I was able to connect a serial cable to it and could log the boot sequence
it is stuck at "Starting program at 0x00008000"
It does allow upgrading firmware (original Asus, Merlin etc.)
but it does not seem to pass this step.
I can interupt the bootloader: CFE 7.14.131.1608 (r589038)
and erase NVRAM etc.
but still no effect.
I have also tried loading an old version of the (Merlin) firmware (in case of incompatibility with the bootloader).
RT-AC88U_380.57_0.trx (I think it is from late 2015)
I even tried to load a dd-WRT version.
but this rebooted itself after it started the linux kernel... and never got out of this loop.
I have no clue what to try next: please help / suggestions.
- how can i diagnose whether it is a firmware problem , or hardware ?
- which bootloader belongs to which firmware level ?
- how can i upgrade a bootloader
- if I erase the NVRAM (after or before the FW upgrade) it does not seem to change content when I use NVRAM SHOW to look at it and compare to other logs.... ?
thanks in advance
kind regards Pascal
thanks in advance
kind regards Pascal
