I have a small office with a network inside.
This network is composed by:
3-4 Wireless notebook with windows
3-4 Wireless notebook with Mac
2 Wired Desktop Mac
1 Laser Printer wired attached to the router
1 NAS also wired attached to the router
The router that I use now is very simple.
I'd like to be able to connect to my NAS by Remote, using internet from external my network.
This functionality needs DDNS and Port Forwarding.
Then, I have read about VPN, and I'd like to know some more about it and about its tunneling protocols (IPsec...ecc)
My questions are:
1-I have to change my router and I need that it will have:
a-wifi
b-supports 10 connections VPN at the same time
c-DDNS
d-Port Forwarding
e-switch Gigabit integrated (possibly...)
what kind of router and what model do you advise me?
I'd like to have a VPN tunnel with a minimum of performance....
2-witch tunneling protocol do you suggest???
3-on the client side of the VPN tunnel, to start the connection do I need to install a software??
Is it possible to have the NAS resource available like a normal HD, so that when I press it, then automaticly it will start the VPN tunneling??
the tunneling will we used with MAC pc and WIN pc too.
last think: My internet provider is an ADSL, so, the router should have the ADSL 2/2+ modem integrated.
Thanks a lot for any suggestion and sorry form my english.....
Bye!
2 Wired Desktop Mac
My questions are:
a-wifi
c-DDNS
d-Port Forwarding
Bye!
