Hello all,
I cannot find a similar topic using the search. I have a RT-86U running Merlin 384.9. I use NordVPN and have configured that connection in the openVPN client section in accordance with the NordVPN manual. I have configured an OpenVPN server which I use to access my LAN devices from any location outside of my own LAN. The NordVPN client uses a 10.8.8.0/255.255.255.0 IP mask, the internal LAN is 10.1.0.0/255.255.255.0, the openVPN server uses 10.16.0.0/255.255.255.0.
The issue described:
I think it is somwhere in the routing where the response from my LAN devices gets redirected through the NordVPN connection to my phone based on the openVPN client strict policy. The routing table in the GUI curently looks like this (the blurred is my ISP external IP address):
I am not savvy enough to find my way to a solution in the command line where I guess I need to put in place a rule somewhere that makes sure that all replies from LAN (10.1.0.X) devices to clients connected to the openVPN server (10.16.0.X) always get redirected through the WAN connection instead of the NordVPN...?? Would this be the solution or is there a better way? Need some help from experts here. Thanks!
- In all situations I can connect to my openVPN server using my phone on 4G;
- In all situations I can connect to my RT-86U through SSH (10.1.0.254) when on the openVPN server;
- I cannot access clients in my LAN 10.1.0.X when connected to the openVPN server AND when the openVPN client is connected to NordVPN. The LAN device I try to connect should use the NordVPN VPN allways (configured in the openVPN client strict policy);
- I can access clients in my LAN 10.1.0.X when connected to the openVPN server AND when the openVPN client is disconnected from NordVPN.
- In this situation the LAN device I try to connect should allways use the NordVPN VPN (configured in the openVPN client strict policy);
- I can access clients in my LAN 10.1.0.X when connected to the openVPN server AND when the openVPN client is connected from NordVPN.
- In this situation the LAN device I try to connect should allways connect using the WAN connection (configured in the openVPN client strict policy);
