Accessing my modem GUI
tarassippo
Hi All,
Searching the Internet for a solution, I read that in order to access my modem GUI (which is connected to an RT-AC66U_B1 with Merlin v384.12) I should have had simply typed from within a SSH session the following command:
ifconfig $(nvram get wan0_ifname):0 192.168.1.2 netmask 255.255.255.0
being the IP modem address 192.168.1.1
And it actually works, so happy days...
The article also mentioned a second command, that is
iptables -t nat -I POSTROUTING -o $(nvram get wan0_ifname) -j MASQUERADE
which I didn't type as I have no clue whatsoever what it does and with the first command I am able to access the modedm GUI.
So, can someone please explain to me what that second command does and whether it's necessary (perhaps for security reasons ?) that I should also include/type in that command ?
Tia.
Meanwhile wanted to go one step further and I thought it would be nice to have a script which could run the command every time the rooter must be rebooted...
I had a read of this: https://github.com/RMerl/asuswrt-merlin/wiki/User-scripts and I've created a file called wan-start and saved as Unix script file with Notepad ++
then copied that in the /jffs/scripts/ directory with WinSCP
and I've enabled JFFS
and I have set the script being executable as per Merlin guide...
I did reboot the router a few times but unfortunately the script seems not running as I have to input the command through SSH in order to access the modem GUI, what am I missing ?
Thanks.
Thanks, but like I said in the first post, I can access the modem GUI...
My 2 questions were about a second command and the script which doesn't run when I reboot the router...
So, I fixed the script issue, that is I just had to add sleep 20s and now it works.
Any networking savvy willing to advise if I'd have any security issues not running the second command ?
Tia.
