Unibrowser
Hello! I finally got my brand new pair of ECB6200K02 in the mail. I quickly got to work installing everything. First I will tell you my issue. My internet speed usually sits at about 470-480mbps(Spectrum cable), but now it is constantly 15-20mbps.
So I went up into the attic and swapped the Coax splitter that the tech had installed with a Moca certified one. The one the tech put there is a 5-1002mhz splitter. I replaced it with a Moca cert one that is 5-1675mhz. I also installed a Moca POE filter on the input of that splitter(coax that comes from the street).
I installed the first adapter in the living room next to the router.
Coax>Moca splitter>coax to modem/coax to adapter>Cat5e to router.
Media room:
Coax>adapter>Cat5e to tp link switch.
Both the power light and the coax lights on the adapters are both lit solid and I transferred a movie to my NAS and i got 107MBps(gigabit speeds).
After I installed all this, my internet speed is trash, I am getting 5% of my normal bandwidth. Someone please help me.
Thank you!
Media room:
Thank you!
