octopus
Part of the Furniture
Evey time I go go Adaptive Qos TAB firewall alwas restart even if i dont use it.
Is it possible to fix so it only restart when its in use?
Sep 13 10:47:30 kernel: * Make sure sizeof(struct sw_struct)=160 is consistent
Sep 13 10:47:31 kernel: IDPfw: TrendMicro forward module ver-1.0.31
Sep 13 10:47:31 kernel: IDPfw: Apply module param dev_wan=vlan11
Sep 13 10:47:31 kernel: IDPfw: Apply module param sess_num=30000
Sep 13 10:47:31 kernel: IDPfw: Init chrdev /dev/idpfw with major 191
Sep 13 10:47:31 kernel: IDPfw: IDPfw is ready
Sep 13 10:47:31 kernel: sizeof forward param = 160
Sep 13 10:47:51 kernel: mod epilog takes 0 jiffies
Sep 13 10:47:51 kernel: IDPfw: Exit IDPfw
Sep 13 10:47:51 kernel: Stop the IPS/AppID engine...
Sep 13 10:47:51 kernel: IDPfw: Exit chrdev /dev/idpfw with major 191
Sep 13 10:47:51 rc_service: bwdpi_check 948:notify_rc start_firewall
Sep 13 10:47:52 start_nat_rules: apply the nat_rules(/tmp/nat_rules_vlan11_vlan11)!
Sep 13 10:47:53 custom script: Running /jffs/scripts/firewall-start (args: vlan11)
