Unbound adblockers - What does unbound manager do differently?
akirru
Hi all,
first of all thanks for the all of the continued hard work. I love using entware and its addons.
So I have made a discovery. I don't understand why but the unbound manager is more powerful for me than anything else I've used apart from a browser adblock. I have tried many dns adblockers such as Pi-Hole, Ad-away home and Diversion. But nothing blocks ads like unbound manager. The others work relatively well but unbound manager is the only one that blocks adds within my firetv apps. I have no adverts in 40d,Plutotv etc. But I noticed it is using the same blocklist as pi-hole and Diversion standard.
So could you tell me what it's doing differently?
Wonderful and useful app though.
Andy
Diversion includes a hard-coded whitelist that allows some major ad domains in order to allow ads on snbforums.com. That might explain why it could be less effective than Unbound or Pi-Hole on the rest of the internet, but it wouldn’t explain Pi-Hole underperforming Unbound.
@dave14305 , What lists to you recommend using for Unbound? Or what list do you use
As I mentioned I tried several blockers and the only difference I could find was the youtube adblock. I know Diversion has something for this too. But even with this disabled the ads wont play. I just discovered this by accident one night. I'm not complaining. Unbound blocks the same ads as pi-hole etc on the browser and it doesn't work with youtube ads etc But as I said it will block most ads on firetv apps.
Another thing I've noticed is that some sites will detect an adblocker with unbound but don't when I'm using pi-hole etc. So it must be doing something differently.
I use the Standard list in Diversion.
Thanks. So Unbound just uses port #53 from the ISP?
Or would DoT be better to run .. Guess it all comes down to privacy to each of there own
Default blocksites file (StevenBlack source only) used by unbound_manager currently uses 60525 domains
[✔] Ad and Tracker Blocking (No. of Adblock domains=60525,Blocked Hosts=10,Allowlist=19,Blocked Country=10)
[✔] YouTube Ad Blocking (Forcing to use YT IP 173.194.129.201, No. of YouTube Video Ad domains=8)
Adding additional blocksites sources bumps the domain count to 229582
e.g.
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
https://www.stopforumspam.com/downloads/toxic_domains_whole.txt
#TikTok
https://raw.githubusercontent.com/llacb47/mischosts/master/tiktok-hosts
https://raw.githubusercontent.com/mitchellkrogza/The-Big-List-of-Hacked-Malware-Web-Sites/master/hacked-domains.list
https://blocklist.cyberthreatcoalition.org/vetted/domain.txt
#Zones_in_unbound_format
https://gitlab.com/my-privacy-dns/rpz-dns-firewall-tools/unbound/-/raw/master/nxdomain/adaway/mobileadtrackers.zone
https://gitlab.com/my-privacy-dns/rpz-dns-firewall-tools/unbound/-/raw/master/nxdomain/mypdns/mypdns.adware.zone
https://gitlab.com/my-privacy-dns/rpz-dns-firewall-tools/unbound/-/raw/master/nxdomain/mypdns/mypdns.typosquatting.zone
[✔] Ad and Tracker Blocking (No. of Adblock domains=229582,Blocked Hosts=10,Allowlist=19,Blocked Country=10)
It shouldn't do anything different, other than returning NX_DOMAIN vs. a Null IP (0.0.0.0) or even a pixelserv-tls IP. Perhaps that does something different. Personally, I am now using a Null IP (0.0.0.0), but was using NX_DOMAIN for quite a while with limited difference.
I dont´t know exactly but the only way for blocking of advertisements via DNS without compromising the DNSSEC verification: RPZ - firewall DNS.
I use E2guardian.
Hi,I'm sorry to use the topic, but I don't think it's pointless to open a new one, for a little help .I tried Unbound, but I had a problem with blocking ads. I tried to uninstall it, but when option 2 is selected, it does not uninstall. Can you help me remove it?
As per the prompt, you need to reply 'Y' (uppercase character rather than lowercase 'y') to confirm/action the uninstall.
Thank you. While looking for ways, I logged in through WinSCP and deleted the files manually. I was deceived because the options of most add-ons do not require a capital letter, and nowhere did it tell me that I choose a non-existent letter as a confirmation. You guys are great. Thanks to everyone for their work.
Install issue I have not had before:
Generating unbound-anchor 'root key'
libunbound error: udp connect failed cannot assign requested address port 53
This line appeared 2-12 times during initial install and each subsequent update attempt until finally completing without errors after about 20 tries.
What does it mean and should I be concerned? Install appears to have completed successfully and unbound is working fine as far as I can tell.
