Unbound adding additional rpz zones
David Donlin
Hi Folks, simple title but I bet a complex answer, Whats the procedure to add more/additional rpz zones to the unbound configuration?
If using unbound_manager; in advanced mode, there are options to edit the contents of the Ad Block lists:
i  = Update unbound and configuration ('/opt/var/lib/unbound/')     l  = Show unbound LIVE (Loglevel=1) log entries (lx=Disable Logging)
z  = Remove unbound/unbound_manager                                 v  = View ('/opt/var/lib/unbound/') unbound Configuration (vx=Edit;vh=help)
x  = Stop unbound                                                   vb = Backup current (/opt/var/lib/unbound/unbound.conf) Configuration [filename]
        rl = Reload Configuration (Doesn't halt unbound) e.g. 'rl test1[.conf]' (Recovery use 'rl reset/user')
?  = About Configuration                                            oq = Query unbound Configuration option e.g 'oq verbosity' (ox=Set) e.g. 'ox log-queries yes'
sd = Show dnsmasq Statistics/Cache Size                             s  = Show unbound Extended statistics (s=Summary Totals; sa=All; http://10.88.8.1:80/user4.asp)
        adblock = Install Ad Block [uninstall | update | track]
DisableFirefoxDoH = Disable Firefox DoH [yes | no]                  youtube = Install YouTube Ad Block [uninstall | update]
Stubby = Enable Stubby Integration                                  DoT = Enable DNS-over-TLS
        firewall = Enable DNS Firewall [disable | ?]
bind = BIND unbound to WAN [debug | disable | debug show]           vpn = BIND unbound to VPN {vpnid [debug]} | [disable | debug show] e.g. vpn 1
scribe = Enable scribe (syslog-ng) unbound logging                  ad = Analyse Diversion White/Block lists ([ file_name [type=adblock] ])
dnsmasq = Disable dnsmasq [disable | interfaces | nointerfaces]     ea = Edit Ad Block Allowlist (eb=Blocklist; eca=Config-AllowSites; ecb=Config-BlockSites; el {Ad Block file})
dumpcache = [bootrest] (or Manually use restorecache after REBOOT)  ca = Cache Size Optimisation [ min | calc ]
        views = [? | uninstall] | {view_name [? | remove]} | {view_name [[type] domain_name[...] | IP_address[...]] [del]} ]
        safesearch = Enable Safe Search [disable | status | ? ] e.g. redirect google.com to forcesafesearch.google.com
        localhost = Add { domain_name {IP_address | del} }
dig = {domain} [time] Show dig info e.g. dig asciiart.com           lookup = {domain} Show the name servers used for domain e.g. lookup asciiart.eu
dnsinfo = {dns} Show DNS Server e.g. dnsinfo                        dnssec = {url} Show DNSSEC Validation Chain e.g. dnssec www.snbforums.com
links = Show list of external URL links
[Enter] Leave Advanced Tools Menu
e  = Exit Script [?]
A:Option ==> ecb
    Ad Block file '/opt/share/unbound/configs/blocksites' NOT changed....Ad Block update skipped
e.g. there are three additional RPZ files in RPZ format (the last three entries) defined in '/opt/share/unbound/configs/blocksites' in this post
If you do decide to edit the file outside of unbound_manager using say nano, you can either wait for the daily cron job, or manually refresh the rules on demand - use
e  = Exit Script [?]
A:Option ==> adblock update
If using wg_manager; in advanced mode, there are options to edit the contents of the Ad Block lists:
e  = Exit Script [?]
A:Option ==> ecb
then you can either wait for the daily cron job, or manually refresh the rules on demand - use
e  = Exit Script [?]
dont you mean unbound_manager ? I wonder if you coded this into work with wireguard manager as well.
Lynx cake-autorate: adding support for Asus Merlin Asuswrt-Merlin AddOns 47
