Adding sshfs support to dropbear?
zerophase
I'm trying to add sshfs support to dropbear, by compiling openssh-sftp-server into it. I'm following this guide, but it seems like the environment is a bit different for Merlin. I get to this point with the perl compiler.
perl -pi -e 's/\/usr\/libexec\/sftp-server/\/opt\/libexec\/sftp-server/g' dropbear[\quote]
But it either doesn't add the functionality since usr/libexec/sftp-server doesn't exist on the box, or I'm still using the version of dropbear that comes with the router. (When I check the ssh process it shows a version from a year ago)
Anyone able to help out?
Simply compile it and copy it to the right path.
The compile commands that tutorial gives aren't correct for Entware. There isn't a /usr/libexec or sftp-server reference on the machine outside of /opt/libexec. So, I think I need to run different compilation commands. (I'm not all that familiar with perl)
How would I go about updating the machine to use a more recent version of dropbear? I installed it from opkg, but the system still runs the older dropbear.
I thought you were refeering to ASUS FW not Entware. :)
ASUSWRT:
[22:22:47] [R] Host key algorithm ecdsa-sha2-nistp521, size 512 bits.
[22:22:47] [R] Fingerprint (MD5): 06:ed:d5:e1:fe:ec:9f:b7:1f:20:43:fd:6f:63:80:00
[22:22:47] [R] Key exchange: diffie-hellman-group1-sha1. Session encryption: aes256-ctr, MAC: hmac-sha1, compression: none.
[22:22:47] [R] Auth Type: Password
[22:22:47] [R] Authentication succeeded
[22:22:47] [R] SSH Connection open
[22:22:47] [R] Connection established with dropbear_2015.68 (SFTP v3)
[22:22:47] [R] SFTP Connection Ready
[22:22:47] [R] Retrieving directory listing...
[22:22:47] (debug) [cache :: add :: new] /tmp/home/root/
[22:22:47] [R] List Complete: 268 bytes in 0,02 seconds (0,3 KB/s)
If you use WinSCP you can login to SSH Servers via SCP protocol not SFTP, you need sftp-server from OpenSSH to make it work together with Dropbear SSH server to work with SFTP protocol.
