I have run into a problem when trying to enable a simple port-based VLAN.
Once the appropriate scripts and config files are put in place, the VLAN seems to be set up OK, but the 5 GHz radio is disabled and cannot be restarted using the GUI.
The Advanced Settings > Wireless web page does not appear properly (only the General tab appears) and the Apply button has no effect.
Attempting to enable the 5 GHz radio in other places, such as on the Guest Network page, has no effect when Apply is pressed.
Removing the script and config file again allows the radio to start after a reboot.
Anybody have any ideas why configuring a VLAN would shut down the 5 GHz radio?
Firmware Version: 378.54_2
nat-start script:
#!/bin/sh
# lan ports 1-3 assigned to vlan1
robocfg vlan 1 ports "2 3 5 7t"
# port 4 to vlan4
robocfg vlan 4 ports "1t 7t"
vconfig add eth0 4
ifconfig vlan4 192.168.30.1 netmask 255.255.255.0 up
iptables -I FORWARD -i vlan4 -m state --state NEW -j ACCEPT
iptables -I FORWARD -i vlan4 -o br0 -m state --state NEW -j DROP
iptables -I FORWARD -i br0 -o vlan4 -m state --state NEW -j DROP
iptables -I INPUT -i vlan4 -j ACCEPT
dnsmasq.conf.add file:
interface=vlan4
dhcp-range=vlan4,192.168.30.100,192.168.30.200,255.255.255.0,86400s
dhcp-option=vlan4,3,192.168.30.1
dhcp-option=vlan4,6,192.168.30.1,0.0.0.0
nat-start script:
#!/bin/sh
# port 4 to vlan4
vconfig add eth0 4
interface=vlan4
