Adding vlan to lan bridge
Algimantas
Hello,
I would like to add vlan6 to br0 bridge.
I tried changing nvram directly like nvram set "lan_ifnames=vlan1 vlan6 eth1 eth2" but after reboot everything goes to default.
Any ideas?
Did you commit it?
on MIPS
robocfg vlan 6 ports "0t 8t"
vconfig add eth0 6
brctl addif br0 vlan6
on ac56/68
robocfg vlan 6 ports "4t 5t"
vconfig add eth0 6
add it to a script
Very poor taste to insult someone when you're looking for 'support'.
And btw, he supports what he releases, not every possible usage that random people can dream up. ;)
insult I do not want anyone
Fair enough.
Patience (specifically the lack of it) shows the opposite of what you intend though. :)
Fair enough.
:D:D
on ac56/68
robocfg vlan 6 ports "0t 5t"
vconfig add eth0 6
add it to a script
It's not work :confused:
re read the thread; though i don't think you know what you want.
you might want
robocfg vlan 1 ports ""
robocfg vlan 6 ports "0 1 2 3 4t 5t"
or
robocfg vlan 1 ports "0 1 2 4 5t"
robocfg vlan 6 ports "3 4t 5t"
or
robocfg vlan 6 ports "3t 4t 5t"
That's what I want, and Algimantas too, we have
vlan6ports=2 3 4t 5
vlan1ports= 0 1 5*
vlan6 is a IPTV tagget, everything work fine, but IPTV traffic don't forward to vlan1 ports and wifi. Using Tomato firmware i can use this command (nvram set "lan_ifnames=vlan1 vlan6 eth1 eth2"), then iptv enable on all ports and WIFI.
I do not know any other way to multicast traffic was on lan port and WIFI. IGMP proxy and IGMP snooping don't help, maybe need try do that with iptables, but i don't now how.
