AdGuard + Unbound from Pi2 to AX56U
mattleg
Trying to transition my Unbound + AdGuard setup from a standalone install on an old Pi2 to fully integrated into my AX56U router. I have everything all up and running on my AX56U, but I noticed the router seemed to struggle processing wise. The Pi2 would take a couple minutes to fully process the block lists, 10 in total. The AX56U on the other hand was 10 minutes or more - in that time the web UI would lockup, WiFi may drop, and I assume AdGuard crashed since the logs showed it being restarted a couple of times.
I expected the router to be a bit slower, but not this bad. Been happy with the Pi2 doing the DNS work, just wanted to try an all-in-on setup. I'm assuming I need a better router like an AX86U for AdGuard to run well, thoughts?
Thanks for confirmation. I'm sure my list count is not helping the issue, and most certainty has redundancy. Thinking I will stick with the Pi2 doing the DNS work for now. Maybe wait for be / Wifi 7 routers to arrive, or get a AX86U on clearance or used.
AdGuard DNS filter 48,579
https://adguardteam.github.io/HostlistsRegistry/assets/filter_1.txt
AdAway Default Blocklist 7,365
https://adguardteam.github.io/HostlistsRegistry/assets/filter_2.txt
OISD Blocklist Full 337,284
https://adguardteam.github.io/HostlistsRegistry/assets/filter_27.txt
Steven Black's List 171,078
https://adguardteam.github.io/HostlistsRegistry/assets/filter_33.txt
Dandelion Sprout's Anti-Malware List 14,193
https://adguardteam.github.io/HostlistsRegistry/assets/filter_12.txt
The Big List of Hacked Malware Web Sites 13,478
https://adguardteam.github.io/HostlistsRegistry/assets/filter_9.txt
Malicious URL Blocklist (URLHaus) 24,073
https://adguardteam.github.io/HostlistsRegistry/assets/filter_11.txt
HaGeZi - Multi Pro Protection 450,007
https://raw.githubusercontent.com/hagezi/dns-blocklists/main/adblock/pro.txt
HaGeZi - Threat Intelligence Feeds 607,115
https://raw.githubusercontent.com/hagezi/dns-blocklists/main/adblock/tif.txt
HaGeZi - Personal 14,310
https://raw.githubusercontent.com/hagezi/dns-blocklists/main/adblock/personal.txt
Stick with either the OISD Full or Hagezi Pro list.
They are both compiled/made up of the other lists you have there - so many duplicate entries.
This will help immensely.
