AdGuardHome AdGuardHome - Any way to see IP addresses of Guest Networks?
poolbeetse7en
I have an Asus AX56U router with latest Merlin firmware. I have actually moved AGH off my router to a local N100 powered mini PC running Docker. I've got it all working fine however, one thing I noticed, which I think was the same when I had AGH running on the router, the query logs do not populate IP addresses from the Guest Network. It definitley still works, but they're just not populated, or they come under my router IP address. Is this simply a limitation of using a Guest network or is there a way to fix this? My non Guest networks work absolutely fine. Appreciate the help. Thank you!
