I
infamous_panda
Guest
Noob here,
I have been looking all over for a clear answer for this with no luck yet. I have heard that gigabit switches and routers automatically throttle down the speed of the network to the slowest connected device... okay.
I am preparing to set up a gigabit network for 5 room in my house and will be running and installing cat6 cable and wall plates this weekend. I D-link 825 router which has 4 gigabit ports which will be located in the office and I plan to buy a gigabit switch to share the connection with the other 4 rooms.
In the office will be three computers with gigabit ethernet ports and a still to be purchased canon multifunction with a 10/100 ethernet port. My question is will attaching this printer drop the entire network down to 10/100, will it drop down just the computers directly connected to the router? Will it drop down the speed only when the multifunction is being accessed. Is if does, then is there a workaround? Should I look for a wireless printer?
Thanks for any input.
Infamous_panda
Infamous_panda
