ADSL giga port, dual band exist?
frustin
Apart from the linksys WAG320N (which cant use both radios simultaniously). is there any other routers that match the discription that have an ADSL modem inside?
Trust me, you dont want this.
Good modems are dirt cheap and easy to find. In contrast, there is NO wireless router than everyone is happy with. You research the generally accepted DIR 655 or Netgear 3700 and even those have a lot of bellyaching.
For $15 bucks you can pick up a new or used modem that you will never look at again or worry about. Buy it and then you can spend the rest of your life trying to find that perfect dual band wireless router. Because you will.
Some folks prefer to keep their ISP's modem independent of their router for obvious reasons.
Still more folks prefer to keep their router separate from the WiFi access point. Because of the importance of a good/trusted router/firewall.
me.. the cable modem (owned by TimeWarner) is in the garage. rarely touched. The router and WiFi stuff is indoors.
