Questions 3 and after are my main concern, please skip to that if you must. : )
1) Say you have a router that operates on n. This gives you a max bandwidth/speed of 300 Mbps when communicating with other n devices, right?
2) If you have 4 x n devices linking to this n router at the same time -> Device A requires 100Mbps, B requires 70Mbps, C requires 70Mbps, D requires 100Mbps (total simultaneous req of 340Mbps). Let's say they all req the same QOS priority. How does the router deal with the additional 40Mbps or more that it cannot accommodate?
3) If, say, you have 3 x n devices in your router's 802.11n LAN - which it can accommodate easily - but you add an 802.11b device and also a an 802.11g device, what happens to the overall bandwidth/speed? Does everything go down to the lowest common denominator? Does the router suddenly open a special new communication channel for the b and then another for the g device? (I'm assuming the overlapping frequencies would make things even more complicated, so I guess we should first theorize the answer as if frequency interference is not an issue, and look only at data transfer issues.)
4) What would your setup options be for creating such special new communications channels?
5) How would such new comm channels affect the n channel's bandwidth? I assume it would eat into the MIMO radios' ability to send/receive bits on the n range?
6) Say your wireless LAN operates nicely on 802.11n with bandwidth up to 300Mbps, but your 802.11n router is connected to the web via an ADSL modem that has a max throughput of 24Mbps. What would be the value of the 300Mbps LAN if the uplink is only 24? I'm assuming we are talking a major bottleneck here?
