Hello all,
I am seeking advice/help on getting my home MoCA network operating. I have tried Googling/searching for an answer and followed some advice I have come across but it doesn't seem to be working. I have not contacted any manufacturer and will do so if no solution can be found here in the forums.
Context:
I recently moved into a rental property, a three storey townhouse. In my very rough diagram I have labeled the levels Lower, Main and Upper. The ISP is Comcast/Xfinity. My intent is to have my modem/router connected on the Main level and run Wi-Fi (which I currently do) for handheld devices, streaming etc. and then run a basic MoCA setup allowing a wired/ethernet connection on the upper level to my desktop. The reason for this is to enjoy a faster connection without any WIFI interference. No cable TV is to be connected.
The cable box is outside the lower level and as you can see in the attached picture, is a bit of a mess. There is the 'inbound' coax from the ISP when feeds into an Extreme branded 3-way splitter. The three 'outbound' coax cables then go to the respective levels of the house, giving an access point on every level. The cable for the Upper level runs external to the house before entering.
I have a Netgear Nighthawk C7000 modem/router (DOCSIS 3.0 if that matters). This was originally plugged into the coax on the Main level and internet connectivity both wireless and wired was fine. I did note there was a coax filter/POE filer attached to the coax coming from the wall.
The two MoCA adapters I am using are Actiontec ECB6250K02 MoCa 2.5 network adapters.
Initially I connected the coax to the first MoCA adapter on the main level by coax, with the filter attached, then ethernet to the NetGear M/R. The second MoCA adapter was connected to coax on the upper level. This set-up did not work and upon research, realised the filter needed to be on the outside of the home network, i.e. at the point of entry from the ISP to prevent data flowing off residence so to speak.
I also noted that the splitter in the box was rated 5-1000Mhz. upon some reading my understanding is that I needed a broader range to support MoCA. I am aware that a number of posters have recommended Holland splitters but due to delivery time and wanting to sort this sooner than later I ordered and received a BAMF 6-way bi-directional splitter https://www.amazon.com/gp/product/B01KCY5MBU/?tag=snbforums-20
I replaced the Extreme splitter with the BAMF, with the filter on the incoming connection. I connected the upper and main level coax. On the main level, the MoCA adapter was connected to coax, then ethernet to Netgear M/R. On the upper level, the second MoCA adapater was connected to coax. Whilst I get a green indicator on both adapters for the coax and ethernet connections, my modem/router never seems to receive internet. The ethernet light is lit, but the downloading/downstream icon remains flashing.
I have tried unplugging, resetting and all that. I have tested the MoCA adapters by connecting them separately to the modem/router by ethernet and coax and get solid green lights indicating no fault. I have connected the modem/router to the coax on the upper level and receive internet both wired and wirelss no problem, but as soon as I try the MoCA network with my modem/router, it never connects.
So from here:
Any help would be greatly appreciated.
Cheers,
Mark
Context:
So from here:
- Am I missing something obvious?
- Could it be an issue with filter and do I need to replace it (I can supply a photo)?
- Is there any setting I need to change on my modem/router ? I have tried to find information on this but have been unsuccessful.
- Is it an issue with the splitter? Noting I put a 6-way in due to time constraints, do I need to only use a splitter for the number of connections I will use (there is an unused coax in the box, I believe this is a second upper level connection potentially as there are other coax points which don't connect to the internet currently)
- Could it be faulty or inadequate coax cables? I don't know the wiring of the house at all beyond the information I have provided, so I am not ware or can confirm if there are any splitters behind walls, and I am not sure if there are different spec coax that could affect this.
Cheers,
Mark
