HyperAdept
Hello All, Hoping for some advice from the SNB community.
I am looking to buy a 2 bay NAS device primarily for streaming media around My home but also to use as personal cloud storage.
I do not require media transcoding as all the devices I will be streaming to have far more advanced on the fly media decoding inbuilt ( Nvidia Shield Pro Android TV ) - I simply require the fastest most robust all round file transfer performance available that will come as close as possible to saturating a Gigabit wired connection consistently.
I also do not require a multitude of Apps to run on the device either as I prefer to utilise client end applications and concentrate on simple data throughput.
I intend to set up a few NFS shares ( for media ) and simple shares running from a Macbook Pro and a windows PC.
I have a budget of £200 - £300 (Gbp)
I will be fitting My own Drives ( 2 x 3TB WD red NAS HDD)
I am looking for opinions and user input for the following devices, as well as suggestions of other NAS units I may have overlooked.
Western Digital Expert Series EX2100 (£189.99 and My current favourite choice)
QNAP TS-251+ ( almost identical Specs to TS-253 pro costs about £60 less - May be overkill for My needs)
QNAP TS-251 ( As above but with dual core - My #2 choice)
Synology DS215+
Synology DS216 ( Non play model )
Any input from the community would be greatly appreciated , especially from users with personal experience of any of the above NAS units, I have obviously already checked The SNB Nas rankings but would also like to hear from users own experiences with these Units as numbers often only tell part of the story.
TLDR - Recommend Me a NAS with Great I/O for between £200-£300 Gbp
Synology DS215+
