I am seeking for some appropriate recommendations for distributing my ethernet LAN to a detached garage to which the laying of a dedicated ethernet cable is not practical. Accordingly, alternate comparative solutions are sought together with the various pros and cons involved as well as some suggestions to the optimal means of implementing said solution(s).
To offer some background:
The garage, whilst detached, is in close proximity to the house (a small bungalow) and already has dedicated mains power although not ethernet. Ethernet distribution serves the front of the property via a pair of wireless mesh routers though they are located at the opposite end of the property to the garage. Provision of a dedicated buried ethernet cable is out of the question due to the preclusive cost of digging a trench the entire length of the existing concrete driveway.
The two routers in question are both Asus AX Routers (an AX88U and an AX86S) running the current Merlin firmware. They are presently configured in 'Mesh' mode with the AX86S (situated mid property) being the secondary node connected by 'wired backhaul' to the AX88U (the primary router Node) at the front of the property. The remainder of (the lesser used) areas are adequately served by Wi-Fi (to iPhone/iPad/Hue Smart Lighting/Misc Smart Homepod Speakers/Devices) with this setup, including to the kitchen (closest part of the building to the garage) at the rear and to the adjacent rear garden area.
Until recently I had not considered providing ethernet connectivity to the rear of the property or to the garage until an automated smart (Apple HomeKit compatible) roller shutter door was recently installed comprising an Ethernet/Wi-Fi bridge device and (in due course) a connected smart HD Security Camera. The Roller Door itself is currently configured with a 2.4 GHz Wi-Fi connection (a limit of the bridge device's restricted 802.11 b/g/n Wi-Fi capability) but this was difficult to establish and at times can be unreliable which is not ideal. However, the bridge device (much like the proposed security camera) provides for an alternate Ethernet connection (via USB to a USB/Ethernet adapter) which would be more secure and reliable. Security is also a prime consideration for the camera installation where, rather than utilising the option of a dual band Wi-Fi connection which the purchased camera enjoys, I would much prefer the added safety and security offered by connecting it to the LAN via it's RJ45 connector.
Initially my thoughts focused upon a 'HomePlug' type Powerline solution with the Tx adjacent to the AX88U and the Rx in the Garage potentially alongside another Mesh AX Router to act as 'wireless backhaul' for LAN ethernet distribution within the garage whilst simultaneously providing an additional Wi-Fi zone serving the rear of the property in much the same way I would have contemplated had it been it practical to lay an underground ethernet cable. However, reading various accounts of HomePlug issues of both connection quality and reliability in garage settings made me investigate whether there were other more practical solutions available.
Those suggested by others have included straightforward AI Mesh routing (third Router) in pure wireless backhaul, Point to Point Wireless Bridging, either in standalone format or within an AI Mesh with node functioning in Wireless Backhaul whilst the Bridge Function operates for the Ethernet connections to the LAN (though I confess I have no idea how to accomplish this nor the practicalities involved), Media Bridge Mode (I am unfortunately ignorant as to what this is and how it might be used) and finally, variations upon my original HomePlug theme!
Perhaps some of the more experienced folks might suggest a more appropriate/best practice solution and the best means by which to implement it.
Looking forward to expanding my very limited networking knowledge and thank you all in advance.
Best regards,
PC Pilot
Best regards,
PC Pilot
