Looking for ASUS Router that supports more than two active VPN connections
more
Hi All,
Any advice on a ASUS Router to purchase that does allow more than two active
VPN connections (Open & Wire) constant 4-6 would be perfect, also may have a 2.5 Wan..
I would imagine have to flash with Merlin.
I have TUF AX 3000 & TUF AX4200 routers at present and of course only two active allowed,
and not supported I believe with Merlin
Any advice appreciated.
Regards
I don't understand.
Wireguard server:
OpenVPN server:
TUF AX 3000
only TUF-AX3000 v2
TUF AX4200
Hi All,
Regards
Ah, VPN Server or Client?
With VPN server I have OpenVPN, Wireguard and Instant Guard at the same time.
VPN Client? With a SOHO router you will be lucky to get beyond the two you have now and the performance will be lousy. Better to have the VPN Client on your PC's and etc.
I don't understand.
Wireguard server:
OpenVPN server:
only TUF-AX3000 v2
I don't understand.
Wireguard server:
OpenVPN server:
only TUF-AX3000 v2
Thank you for info/
