FloorPizza
So I've read just about every review of every piece of wireless hardware reviewed on smallnetbuilder, a ton of the forum posts, and the "how to buy a wireless router-short version" as well as the long version. And I'm more confused than ever.
Here's my situation:
We're moving in to a neighborhood that has a ton of wireless networks. So I'm thinking I want a dual band router, to start.
Devices will be: two computers and an HP Photosmart Premium printer hard wired to the router in the den, which is where the cable modem will be. Occasionally a laptop will be hard wired, too.
The rest of the devices will be wireless, as the house isn't ethernet wired. There will be an Xbox, TiVo, and Wii connected to a wireless bridge in the living room.
In the bed room, there will be a TiVo connected to a wireless bridge, but I want the bridge to have a multi-port switch on it for future expansion.
So basically I have a small wired gigabit network that needs to have two wireless bridges connected, with the ability of adding wireless laptops to the network on occasion.
We will be transferring a ton of video over the network; I have my main computer set up to archive all of my TiVo recordings (the Tivo's are HD multi tuners), and we'll also be watching NetFlix and Amazon streamed movies over the Tivos, as well. The cable modem will be hard wired to the gigabit wireless router in the den, so all incoming video will have to be streamed wirelessly for playback.
The total range of the network doesn't need to be very long. It's not a large house, and it's all one level. I would guess the max range from the router to the furthest device will be 15 feet and two walls. However, I would like to stay with a two band device in case I need to use any legacy 2.4 ghz devices.
After all this reading and research, I'm convinced I know even less now than before I began.
Any help with suggested components would be greatly appreciated.
Edit: I'm leaning toward the D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point for the two needed wireless bridges, as it's dual band and includes a four port gigabit switch. Any reason to *not* go with this one? I'm aware of the huge WEP and WPA performance hit, but I'm going to be using WPA2. It does look like it takes a good hit for WPA2, as well, but I'm just not seeing any other good .n bridges around...
I'm still waaaaaaaaaaaaaay far away from picking a router, though. Hmm. Maybe I should bite the bullet, and go for the NETGEAR WNDR3700 RangeMax Dual Band Wireless-N Gigabit Router on a leap of faith. Now if the 'egg would just get it in stock. I'd much rather get a proven trustworthy router, but the more I read about them, the less a "clear winner" there seems to be.
