So I’ve done some digging to the best of my abilities, but I can’t fix the problem so here I am.
Ever since I hooked up my new router (RT-BE86U running the latest merlin) my previous one (RT-AX86U running the latest merlin) has been placed upstairs as a wired backhaul AI mesh. My router is set up to direct all DNS traffic to my two raspberry pi’s running pihole+unbound. I have it setup in the LAN-> DHCP settings.
Ever since the old router became a mesh node I see the dns.msftncsi.com domain being request to my pihole every minute. Searching led me to this very forum, and it seems to be a check if the internet connection is there. (Why the MS domain for that though…). My router without AImesh never did this, and the local IP that is requesting it IS the AImesh router so that has be the issue.
I want this not to happen, but again this forum test me to go to Administration -> System, and check under network monitoring. It can use dns for that. But it’s turned off on my main router. Makes sense: I don’t see the queries coming from there. If I check the box, I see the dns.msftncsi.com domain as a default so my conclusion is:
The AI mesh router DOES have the checkbox checked, and thus it’s sending out those DNS requests constantly. But again this forum (so much good info here) tells me I can’t login to the AImesh node separately. Which is true: i get redirected if I enter the local IP of the AImesh node.
So is there any way to get into those settings and turn off that DNS check? I don’t care if the ‘internet is up’ function doesn’t work anymore, I just want that DNS spam gone.
Thanks in advance for any help. (Hopefully the English is ok, not a native speaker).
