Marvin Gage
ASUS RT-AX86U
ASUS RT-AX58U
OK today I found out that AI Protection and was blocking websites even though malicious websites were turned off. How it affected me, why it happened, and how I resolved it.
1. Bufferbloat - Rating was very bad a C as download latency was well over 74+ ms
2. URL were being blocked even though it was turned off
Fortunately I found the article about withdraw consent under policy tab in Administration and that resolved the issue but the real culprit was that a firmware update somehow caused consent to be applied twice.. One was a very old one that was still being applied and the new one from the update. So the policy was being applied twice and ignoring the router settings for the one even though I turned off the malicious website blocking.
Resolution if you have had your router setup for a while and AI Protection is acting up withdraw any policy of sharing and it will reset all AI Protection settings. I was than able to test with it off and enabled and the results were good both ways and very little latency applied and no more sites being blocked.
1. Disabled all privacy consent under Administration > Policy Tab
No AI Protection Enabled
With AI Protection Enabled with IPS & IDPB
The test results were very minimal on impact just need to clear out the old settings by withdrawing consent than re-enable making a huge impact. Strange how the router can apply multiple privacy policies and cause this problem.
ASUS RT-AX58U
Download Active
+15 msUpload Active
+22 msWith AI Protection Enabled with IPS & IDPB
Download Active
+20 msUpload Active
+25 msThe test results were very minimal on impact just need to clear out the old settings by withdrawing consent than re-enable making a huge impact. Strange how the router can apply multiple privacy policies and cause this problem.
