AiCloud and access to the LAN
bmb
I've got AiCloud working in that I can see the USB disk attached to the router, that's great, but can't gain access to other shares.
The AiCloud welcome screen shows PCs on the LAN, and if asleep I can wake them up, but when I click on one connect I get the message "Connection failed!". They have shared folders on that would useful to be able to connect to.
I can also connect to the router OK when clicking Network map, its just the shares on other PCs on the LAN that fail.
Any help would be appreciated.
can you manually wake the client that wont wake up ?
as in a local wake on lan app?
Yes, I can do that, and access all shares.
I only can't connect to the PCs through AiCloud.
I think i had the same problem with "USB Application - Network Place(Samba) Share / Cloud Disk" when it was set to an account, now it is set to disable share without an account and works ok.
maybe try that and set a password?
Thank you for the suggestion, I changed to 'share without account' though still connection fails. Password is set.
I'll have a look at some other settings.
