I'm beggining to use aiCloud app in android, it works ok almost for everything.
I'm using aiCloud smart access.
What I've failed to do is saving files from android app to the windows share.
It works ok from windows (but I don´t like it doesn´t advert you if you upload a file with the same name as one that exists), using chrome, so it's not a configuration problem in windows share.
¿It`s my fail, or it's a aiCloud android app handicap?
