Aicloud cant connect
laracroftonline
hi,
on version 3.0.0.270 i had not any problems connecting to aicloud and when selecting a windows pc i could normally logon to get to my files but on newer Versions 3.0.0.3xx brands i can't connect, the error i get when selecting a windows pc is can't connect. Also logging out on 3.0.0.3xx branches doesn't work.
Can someone help me? I already did 30/30/30 flash with the mini server, cleared nvram and i even did reflash but no result.
i have an rt-n66u
I tried aicloud last night and couldn't get it to work with Merlin's latest. I went back to .271 and it still doesn't work. Just hangs with "finishing setup" on my iPhone .
Servers must be down?
it does work on 270 newer firmware versions it doesn't work so i run merlin 270.26b !
Do NOT use AiCloud on any older version. Anyone can access your files fromt he Internet without having a username or a password. 372.31 (and Asus 372) are the only versions with a secure AiCloud implementation.
Hello,
I started using AICloud Smart Access last week after upgrading to .372.31
I can only get it to work on my Samsung Galaxy S4 when my openvpn client is disabled. I tried selectively routing 192.168.1.1 to my WAN, but that didn't seem to help. Any ideas?
3.0.0.4.372.31 (Merlin build)
RT-AC66U
Tell asus that it doesn't work i constanly getting a error when i select the pc i need documents from! can't connect while this isn;t the case on 270b
