AICloud Cloud Disk Authentication method message
Tuba
I have an RT-N66u router with a USB stick plugged in as my NAS so I can watch movies with other devices on my network.
If I setup a new account and password in the router setting page "USB Application ->Network Place (Samba) Share / Cloud Disk" and try to access it via the AiCloud app on my Android tablet, I get the same pop-up message every time I click a subfolder:
"If you have changed your router authentication method, you need to change settings here, or smart sync will not work."
It offers two Authentication Methods:
  • HTTP
  • HTTPS
No matter which I click and hit OK, or even if I hit cancel, I gain access the folders/files. But the pop-up happens every time I navigate folders (in and out) and it's really annoying.
Searched everywhere and this phrase doesn't seem to exist on the web.
Note that if I access the NAS using the main account (the Username and Password for the router settings page), then I don't get the Authentication Methods pop-ups. But prefer not to use the username and password that gives full access to my router.
Any thoughts?
I think I found the answer and will post here in case someone else has this problem later.
There is a checkbox for "Ask me next time" at the bottom of the notice that I saw when I used a different tablet. The different tablet has a taller screen (1080 vs 800 vertical resolution) so I expect the check box is hidden on the shorter tablet.
So I will try to access the check box (maybe hitting Tab on the keyboard) on the original (shorter) tablet.
