AiCloud GUI question
elbubi
Hi!
I'm crazy (I know...) but I would like to replace the router's image of AiCloud homepage for my 87U image instead of the provided one (look at the green box in the image below).
I have looked all over the router with WinSCP but couldn't find that image to replace for my 87's png.
Does anyone have a clue where is it stored and/or how can I replace it?
Kind Regards and thanks in advance!!!
AiCloud content is under /usr/lighttpd/ .
Thanks for your reply Eric!
Found the picture under "default_router.png" name. When trying to overwrite it with desired one I get a "read-only filesystem" error. Tried to change lighttpd permissions first but encountered same issue.
Any hints to bypass that restriction?
Regards and thanks once again for your support!
The flash is read-only, you cannot change its content without compiling your own firmware.
You might be able to mount bind a replacement file on top of it, using mount -o bind.
Will further investigate that option.
Regards and thanks once again for your kindness.
