AIcloud n00b question - *Resolved*
Pericynthion
Dear all - do I need to do anything firewall-wise to enable AIcloud to work properly? Ihave smart-access switched on and confirmed that the DDNS is registered - but I dont seem to get a response from any devices on a remote network? the AIcloud log is blank too, making me think its a firewall issue...
It works fine locally over wifi (and I can see info in the log), but do I need to expose something external (like either SSH or Web access on the WAN port).
UPDATED: Sorry, I should have dug into the logs a little more. Clear to me from the local etries that WebDav is required - so enabling the Web access on the Wan port did the trick.
