I have a trio of AX86U Pros set as mesh APs with the lastest Merlin. The 5Ghz is set to support WPA3/WPA2. Using Network Analyzer (and confirm by other apps) on my Android, I see that only one of the nodes (not the main node) is advertising as WPA3/WP2. The main node and the other remote node are only advertising WPA2 only.
Is this a known issue?
Thanks.
Thanks.
