elrengo
Hi! I've two Asus Routers: RT-AC3100 & RT-AC66U_B1. Both with Asuswrt-Merlin firmware. These are wire connected with AiMesh config.
The AC3100 is configure as AiMesh Router, connected to my Internet Provider Cable-modem, have attached a WD USB3 1TB HDD where is installed Entware some tools and ruTorrent to be used as seed-box.
The AC66U_B1 is located in the Living-room, connected with it is my Smart-TV, PS3 and my media center: WD HD TV Live. The wire connections is perfect for the media streaming. Also extend my wireless connection.
I've a good pro with AiMesh configuration that the administration and configuration is minimal and my AiMesh node receive all the configuration do it on my AiMesh Router (AC3100).
The bad point is a lot de configuration is lost and can not do it. Samba sharing do not work and maybe some point will be lost. The centralization of the configuration will be only for extend the network.
I've not a good networking knowledge, I required assist from you. I required to recover the samba configuration and DLNA and maybe other custom configuration. I would like to know how I must configure my AC66U_B1 to extend my DCHP configuration from AC3100, I know that will be more easy do not turn on the DHCP server, but i need to that will be other configuration than router must be used. I required to be continue have the same network and the same Wireless Network and SSID. Both devices continues with wired connection.
Thanks.
elrengo.
Thanks.
elrengo.
