New post since I think I used an old thread. Can't find an easy answer after searching.
I have an AC68U which is set up as a VPN client for TV purposes in primary room, connected to a 5G box by ethernet.
The WiFi signal in a second room is poor, and it's where I want to run a second TV off VPN. I've tried powerline adaptors in the past without great success.
If I buy a second AC68U would AiMesh work? I think I read not, due to VPN. Just want to know if there's a relatively simple setup or instructions (you can tell I don't know what I'm doing!) to extend the VPN signal before I buy a second router. Thanks in advance.
