HI guys. I have 2 routers that are using the aimesh. AX56U and AX58U. The both used the lastest firmwares from asus.
The issue is that every hour the internet drops (not the wifi signal). I remain connected to the wifi but there is no internet for 30 sec - 1 min
I checked my ISP logs and the router itself does not disconects. It has to be something with the Aimesh because if i use them as repeater or single router its absolutelly no issue.
I tried to disabled the roaming assist as some reccomended here but issue still persists.
Thank you!
Thank you!
