TheScotsman
While playing with AiMesh and guest network access, I've uncovered a security issue - I think this is kind of an edge case, but given the way many of us hoard and reuse our older hardware I wanted to bring it to attention.
My AiMesh router is a GT-AXE11000, a tri-band router on 2.4GHz/5GHz/6GHz. The AiMesh node is an RT-AC5300, also tri-band but on 2.4GHz/5GHz/5GHz. The RT-AC5300 internals a a little peculiar so perhaps this is specific to that model. I have my main network SSID shared on all three bands of the GT-AXE11000 and SmartConnect enabled. 2.4GHz and 5GHz authenticate with WPA2-Personal (changed from the default WPA2/WPA3-Personal as that appeared to be tripping up a client); on 6GHz it's WPA3-Personal.
What I saw is that on the AiMesh node, the second 5GHz band is UNSECURED; no password required to connect to the network, and it provides connectivity just fine! On my phone's wifi list I can actually see two entries for the network, one with the lock, one without. I'm not sure if the mismatch is because of WPA3-Personal running on the router's 6GHz band (the only options are that or "enhanced open" so no way to test); or if it's not lining up the security parameters because of the frequency difference (maybe it doesn't know what to match with?). In any event, it opened up my core network - the only workaround I've found for now is to disable the radio for that 2nd 5Ghz band on the RT-AC5300 node, which makes the unsecured network disappear.
