I have a weird situation here.
My connection is as following:
This setup works perfectly, but recently I wanted to replace the dumb switch on 2F with another managed switch. The ethernet backhaul stop working once I replace with the switch, no matter how hard I tired. But node 2 that connect directly to the main managed switch never have the issue.
I keep the vlan default with VID 1 in the switch I want to replaced on 2F, try both tag or untag trunk port, still no luck. Anyone have this issue before? I tried to dig into the forum but can't seem to find anything similar to my situation. I don't need a guest vlan for now, and with default factory firmware.
