aru
My router network environment is as follows:
I followed the plugin script provided by the script owner for practice and successfully sent the node's CPU temperature, load, and uptime to the main router. I also categorized the logs for cleaner and clearer display.
Add LogCPUtemp.sh script to the node by myself:
I was surprised to find that after installing multiple plugins on the GT-AX6000, the average CPU usage is 0.1-0.2. However, the CPU usage on the two nodes, AX88U and AX86U, which are only responsible for Wi-Fi forwarding, is as high as 1.0-1.23. Is this due to hardware CPU differences, or is it because the nodes have a heavier workload?
gt-6000
ax88u
ax86u
Scribe - Feature to support AiMesh node(s) log?
I went in the other direction. Got scribe on router and both nodes. Have nodes forwarding to router (A00remote). Syslog-ng filters putting all of it where it suppossed to go. Debating creating my own filters based on the hostname of the AImiesh nodes (logrotate as well), the part two. This...
www.snbforums.com
#!/bin/sh
TEMP=$(cat /sys/class/thermal/thermal_zone0/temp)
TEMP_C_INT=$((TEMP / 1000))
TEMP_C_DEC=$((TEMP % 1000 / 100))
echo "CPU Temperature: ${TEMP_C_INT}.${TEMP_C_DEC}°C" | logger
uptime| logger
gt-6000
ax88u
ax86u
