ChrisA
Is there going to be a problem using a new WiFi 6e main router with an older WiFi 5 router using AiMesh with a wired backhaul? I only have a few modern clients. Most are 2.5 Ghz lightbulbs, switches, door sensors, and the like that need rock-solid connections but have low bandwidth. These IOT clients might be in poor locations like electrical boxes.
The other idea I had was to use a second WiFi 5 router to make a totally separate IOT network on a different LAN but I'm concerned with interference between the two
In short, does AiMesh work well if you try to combine different generation routers?
