AirRadar Problem
antonzippo
Hello all,
i have a following problem.
In my haus (2 Stages) are 2 Asus Routers installed.
In basement ac3200 and on the top stage a ac66U. Both routers have a same SSID-Name with the same password.
Im use as WiFi Client a Samsung Galaxy S4 phone. If my smartphone connected to ac3200 and i'm going to other stage of haus to the ac66U my smartphone will not be disconnected from ac3200, it showing only 1 from 5 Signal bars an internet speed is poor. Bei AirRadar i can set a disconnect rule between -70 and -90dB. How to change it to for sample -60, to disconnect my smartphone early? Or its a problem of samsung?
Im calling very often with skype or whatsup and they still frozen at this times.....
Any other ideas?
