Alerting on temperature and CPU usage
rkrmpg
Before I attempt to create I thought I would throw this question to others.
Has anyone created a script that can send an email alert if any of the temperatures of the router reach x degrees for x minutes
and/or
if CPU usage reaches x for x minutes then send an email alert?
i can think of this interesting, but otherwise worthless script.
    logger -st "Thermal Critical" "Waiting for Things to Cool Down..."
    heattimer=0
    while [ "$(nvram get heattimer)" = "0" ] && [ "$heattimer" -lt "3000" ]; do
        heattimer=$((heattimer+1))
        sleep 1
    done
    if [ "$heattimer" -ge "3000" ]; then
        logger -st "Thermal Critical" "Things Got too HOT!"
                reboot
    fi
:D:D:D
My suggestion: not needed at all - see many discussions in the forum about it!
Some add Notebook Cooler Stands to cool the router - which is completely useless as the Temp is never a problem. :eek:
Alerting on CPU usage
Well, similar to the cooling topic: Not needed, as it's normally not a problem at all.
If the CPU is used it's needed and you can do nothing about it - only in some rare cases in the past (with ill behaving) the router could go ballistic in CPU usage - but this was fixed long time ago. :rolleyes:
You are a true genius. You must be in the computer hardware manufacturing business. I love dropping by this forum every so often to find fascinating facts.
Here are the facts: Router CPUs are build for >100° C temps - but people perfer to belive in Chemtrails and Too High router CPU Temps! ;)
And do not forget to dicuss the high memory usage on Linux/Router systems. A very big problem with no solution... :rolleyes:
I'm not challenging you joe on your greatness. Your facts are amazing and enlightening. Keep on overclocking those consumer grade routers of yours. You're absolutely a genius.
