I have a basic knowledge of iptables and practically no idea how asuswrt hadles the routing / firewalling / security.
1. I installed asuswrt-merlin (380.57) on RT-AC87U and would like to setup a VPN (PPTP) server to only allow incoming connections from a specific ip/ip ranges and drop all others. A sample firewall-start script would be greatly appreciated.
2. default iptables rules seems to be a bit of a mess (default settings, VPN enabled):
Wouldn't these allow any incoming connections to be accepted? And if not, how is port forwarding handled? If I forward a port should't there be an associated rule in the INPUT chain?
3. Where is Guest-Wifi isolation handled? (the rules so the guest-wifi cant access other LAN clients)? I would like to change these rules so even Guest-Wifi clients can connect to the DHCP and DNS services (and only those services) on a local server (Windows server).
Chain INPUT (policy ACCEPT)
target prot opt source destination
DROP icmp -- anywhere anywhere icmp echo-request
DROP all -- anywhere anywhere state INVALID
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ACCEPT all -- anywhere anywhere state NEW
ACCEPT udp -- anywhere anywhere udp spt:bootps dpt:bootpc
ACCEPT icmp -- anywhere anywhere icmp !echo-request
ACCEPT tcp -- anywhere anywhere tcp dpt:1723
ACCEPT gre -- anywhere anywhere
