YazFi Allowing cast traffic from guest network to IoT (media) network
dangkhoa
Hi, new to AsusWRT-Merlin and YazFi! (Not to mention iptables.)
I'm trying to allow my "true" guest network (wl0.1, wl1.1) one-way access to my "media" guest network (wl0.2, wl1.2). The intent being to allow house guests to be able to cast music/video to my speakers/TV.
Per Google's help page "Network requirements for cast moderator", I need to:
  • Allow TCP packets on ports 8008-8009 from sender to receiver
  • Allow UDP packets on ports 1-65535 from sender to receiver
  • Allow UDP packets on ports 1-65535 from receiver to sender
These are the rules I tried to add. I put the following script /jffs/addons/YazFi.d/userscripts.d/allow-guest-access-to-media.sh:
#!/bin/sh
iptables -I YazFiFORWARD -i wl0.1 -o wl0.2 -p tcp --dport 8008:8009 -j ACCEPT
iptables -I YazFiFORWARD -i wl0.1 -o wl0.2 -p udp --dport 1:65535 -j ACCEPT
iptables -I YazFiFORWARD -i wl0.2 -o wl0.1 -p udp --dport 1:65535 -j ACCEPT
iptables -I YazFiFORWARD -i wl1.1 -o wl0.2 -p tcp --dport 8008:8009 -j ACCEPT
iptables -I YazFiFORWARD -i wl1.1 -o wl0.2 -p udp --dport 1:65535 -j ACCEPT
iptables -I YazFiFORWARD -i wl0.2 -o wl1.1 -p udp --dport 1:65535 -j ACCEPT
iptables -I YazFiFORWARD -i wl0.1 -o wl1.2 -p tcp --dport 8008:8009 -j ACCEPT
iptables -I YazFiFORWARD -i wl0.1 -o wl1.2 -p udp --dport 1:65535 -j ACCEPT
iptables -I YazFiFORWARD -i wl1.2 -o wl0.1 -p udp --dport 1:65535 -j ACCEPT
iptables -I YazFiFORWARD -i wl1.1 -o wl1.2 -p tcp --dport 8008:8009 -j ACCEPT
iptables -I YazFiFORWARD -i wl1.1 -o wl1.2 -p udp --dport 1:65535 -j ACCEPT
iptables -I YazFiFORWARD -i wl1.2 -o wl1.1 -p udp --dport 1:65535 -j ACCEPT
After running this, I put my cell phone on my guest network and don't see any of my media devices available to cast using, e.g., Spotify.
On my main network, I simply have YazFi's "one-way to guest" enabled for my media network. I suppose I'm really just looking for "actual guest network" (wl0.1, wl1.1) to have one-way access to my media network (wl0.2, wl1.2). (Although, a separate question of how does one-way to guest work for casting if I need to allow UDP traffic to flow from receiver to sender? Again, new to iptables, YazFi, and AsusWRT-Merlin...)
I'm hoping for some help to point out what I'm doing wrong with iptables (or if this is even close to the correct approach to allowing my "actual guest" network to access my media network).
Well, with my main network, using one-way to guest allows casting to devices on my IoT network just fine - so I could just set up rules to do two-way to guest between the true-guest network and IoT network - but then, how does main network one-way to IoT network work correctly?
As a troubleshooting step(s). Try the scripting without the dport values if you haven't tried it already. Also try just scripting between one set of WiFi not all of them at once. If you can get it working, as you expect or want, for just one of the WiFI bands then you can expand it to all of them.
Hah, I read your post and realized that I needed to actually apply YazFi settings from /jffs/scripts/YazFi. That said, using the rules I set above still doesn't work.
Right now I just implemented the following for complete two-way access:
iptables -I YazFiFORWARD -i wl0.1 -o wl0.2 -j ACCEPT
iptables -I YazFiFORWARD -i wl1.1 -o wl0.2 -j ACCEPT
iptables -I YazFiFORWARD -i wl0.1 -o wl1.2 -j ACCEPT
iptables -I YazFiFORWARD -i wl1.1 -o wl1.2 -j ACCEPT
iptables -I YazFiFORWARD -i wl0.2 -o wl0.1 -j ACCEPT
iptables -I YazFiFORWARD -i wl0.2 -o wl1.1 -j ACCEPT
iptables -I YazFiFORWARD -i wl1.2 -o wl0.1 -j ACCEPT
iptables -I YazFiFORWARD -i wl1.2 -o wl1.1 -j ACCEPT
and this works (except for one app that can't cast to my TV or Chromecasts, but I actually think this is a problem with the Fubo app and not with the network settings.. potentially) - clearly not ideal though if I don't want my media network to reach into my guest network.
Some musings:
  • I think there's some nuance here with Avahi that I can't put my finger on - does Avahi only have clients advertise to br0? (Seeing as how enabling two way communications works, I think Avahi is actually running ok)
  • What are the iptables rules that are being set when I set, e.g., wl02_ONEWAYTOGUEST=true ?
@dangkhoa, not sure you indicated it; but what router, and what specific firmware version are you running?
PS: Also what version of YazFi are you running?
I'm on an RT-AX58U, firmware 3004.388.8_4, YazFi 4.4.4
You may want to try the YazFi develop version (4.4.5) to see if that improves anything.
/jffs/scripts/YazFi develop
/jffs/scripts/YazFi forceupdate
Also make sure you don't have Client Isolation in YazFi.
I'll give 4.4.5 a shot. I also am not running Client Isolation (although after I got this fully working that was my next intended change to my network) - but what would happen if I did so?
I'm trying to read the actual script to understand how exactly one-way-to-guest works and understand why casting to devices on a YazFi network works seamlessly when the source device is on the main wifi, but doesn't work when the source device is also on a YazFi network - I'll post again with my understanding so someone can correct me (or I figure it out and it's useful information for someone else in the future). (Or Martinski or JackYaz can just educate me 😅)
The firewall (iptables) rules for doONE_WAYtoGUEST in the YazFi.sh (v4.4.5) are found starting at line 1727:
https://github.com/jackyaz/YazFi/blob/develop/YazFi.sh#L1727
Another thing to do is to grep the iptables to see what the YazFI entries are. The following will dump all of the iptables entries:
iptables-save
Not sure if the following is the proper command to grep the YazFi entries in iptables as I don't have immediate access to Asus-Merlin router running YazFi to test with.
iptables-save | grep YazFi
This was super helpful (and easier for me to parse than trying to manually run through the script and do all the substitutions myself)! Here's what I found that the script does to allow one-way from main LAN to guest network. (If helpful I can also attach the full iptables-save output in case I'm missing anything else.)
-A POSTROUTING -s 192.168.1.0/24 -d 192.168.55.0/24 -o wl1.2 -m comment --comment "LAN to YazFi 5GHz 2" -j MASQUERADE
-A POSTROUTING -s 192.168.1.0/24 -d 192.168.52.0/24 -o wl0.2 -m comment --comment "LAN to YazFi 2.4GHz 2" -j MASQUERADE
-A YazFiFORWARD -i br0 -o wl1.2 -m comment --comment "LAN to YazFi 5GHz 2" -j ACCEPT
-A YazFiFORWARD -i wl1.2 -o br0 -m state --state RELATED,ESTABLISHED -j ACCEPT
-A YazFiFORWARD -i br0 -o wl0.2 -m comment --comment "LAN to YazFi 2.4GHz 2" -j ACCEPT
-A YazFiFORWARD -i wl0.2 -o br0 -m state --state RELATED,ESTABLISHED -j ACCEPT
I see for the YazFiFORWARD rules, we allow traffic to flow from br0 to wl{1,0}.2 and only allow traffic from wl{1,0}.2 back to br0 if the state is RELATED or ESTABLISHED - I think this was what was missing in my original rules! I'll give this a shot momentarily.
I don't understanding the POSTROUTING rules though - trying to read through manpages, I believe the lines are for any packet that's originating from my LAN (192.168.1.0/24) to be seen by anything on the .55 and .52 subnets to have originated from a .55 or .52 subnet? Not clear if I need these POSTROUTING rules in addition to the YazFiFORWARD rules to make "one-way from guest network to another guest network" work.
All that said, once that does work I think I can start narrowing down specific ports to keep open that correspond to my cast devices, rather than carte-blanche access to the media network.
@dangkhoa, it appears someone else is asking a similar question about trying to enable one way to guest in the 3006 firmware. They posted some code they are using to achieve main LAN reaching their Guest Network Pro clients.
Hi everyone,
Running on the 3006 firmware version, I have 3 guest networks that are isolated from everything. I'd like to have the main network (192.168.0.0/24 on br0) be able to reach one-way to those 3 guest subnets.
I currently achieve this with a firewall-start script that runs the following commands:
iptables -I FORWARD -i br0 -s 192.168.0.0/24 -d 192.168.1.0/24 -j ACCEPT
iptables -I FORWARD -i br0 -s 192.168.0.0/24 -d 192.168.2.0/24 -j ACCEPT
iptables -I FORWARD -i br0 -s 192.168.0.0/24 -d 192.168.3.0/24 -j ACCEPT
I was just wondering if there's any way to achieve the same thing through the GUI, any setting that would do that?
Thanks!
