T.S.Fellow
I have a two router setup, an rtac88u setup as the main router/VPN server. I have a lyra mesh setup as a vpn client of the main router. Then the ISP rented modem.
All devices in the home go through the vpn server, but there are a couple issues.
1. The Lyra always says "IP/routing conflict" when connected as VPN client, however it shows packets going back and forth and shows as connected under a tunnel. So it appears all is good and the routing conflict was ignored.
2. Whenever attempting to use a proxy, the ISP ip still returns using "what's my ip". When I write a config with a proxy, and connect a device, it shows a public IP of the proxy, but when I check the IP on sites like what's my ip, it is not returning the proxy ip, rather it is showing the ISP public IP. If I go to a web browser with a proxy, then the proxy works, or TOR the proxy returns the proxy IP, but through my VPN no proxy IP is ever present.
My question then is, am I even hiding anything from my ISP? Does their rented modem just see all my requests as the last end point before sending and receiving packets? I use smart DNS as well and no DNS leaks. That will return the correct DNS routing. I'm just concerned that I am not really doing anything having all this setup and then the ISP modem just sees the activity. Any help is greatly appreciated.
