Diversion amtm Diversion installation : module download failed (SOLVED)
itibi
Hi!
Running asuswrt-merlin 384.13_10 on RT-AC3200. very happy. Thanks
Trying to install DIVERSION with amtm 3.2.0 and get the error message
Enter option 1
amtm 3.2.0 FW by thelonelycoder
RT-AC3200 (armv7l) FW-384.13 @ 192.168.1.1
The Asuswrt-Merlin Terminal Menu
j3 open scMerlin v2.4.0
j4 open spdMerlin v4.4.1
ep manage Entware packages
dc manage Disk check script dcl show log
sw manage Swap file /mnt/Share_disk 2.0G
i show all available scripts or tools
u check for script updates
amtm options
e exit t theme r reset a about
_____________________________________________
Getting from fwupdate.asuswrt-merlin.net
! Module diversion.mod download failed
! using fallback server diversion.ch
I also have the following UPDATE error on AMTM:
Enter option u
ep manage Entware packages no upd
awm Asuswrt-Merlin firmware 384.13.10
m menu amtm uu force update upd err
! amtm: diversion.ch unreachable
Update(s) aborted, could not retrieve version
Maybe that this is the result of a previous failed installation of diversion !
Can you help ?
I forgot to mention that the problem is still present after a router reboot.
@colin: Thanks for your hint. it solved my problem.
